Column 'OrderUserID' cannot be null
Thread began 5/17/2012 7:16 pm by mpiasecki1437949 | Last modified 5/30/2012 11:47 am by Jason Byrnes | 790 views | 16 replies |
mpiasecki1437949
"Column 'OrderUserID' cannot be null" message and blank confirm page
This is continuation of my post about download center showthread.php?t=26510. Everything works good now except for one thing. When I press checkout the confirm.php page displays blank with this message "Column 'OrderUserID' cannot be null" I check in database table and this column is not null there. I can not complete the translation and go to pay pal for payment. I attached page for review.
downloadcenter (2).zip
on the confirm page, the store order summary behavior is set to use the UserID session variable.
it should be using the SecurityAssist_UserID session variable instead.
your login page is still quire a bit of a mess. you have unneeded instances of the authenticate user server behavior and there is also an instance of the Dreamweaver Login user behavior.
mpiasecki1437949
confirm pge
Jason,
Could you please clear those items from log in page and attache to repply. I ran the SA wizard and this must be left overs, I don not know which items to remove so the log in is still working.
delete this code from line 181 - 223:
// *** Validate request to login to this site.
if (!isset($_SESSION)) {
session_start();
$loginFormAction $_SERVER['PHP_SELF'];
if (isset(
$_GET['accesscheck'])) {
$_SESSION['PrevUrl'] = $_GET['accesscheck'];
if (isset(
$_POST['Log_In_group_Email'])) {
$loginUsername=$_POST['Log_In_group_Email'];
$password=$_POST['Log_In_group_Password'];
$MM_fldUserAuthorization "";
$MM_redirectLoginSuccess "userprofile.php";
$MM_redirectLoginFailed "login_test.php";
$MM_redirecttoReferrer false;
mysql_select_db($database_connlive$connlive);
$LoginRS__query=sprintf("SELECT UserID, UserEmail FROM users WHERE UserID=%s AND UserEmail=%s",
GetSQLValueString($loginUsername"int"), GetSQLValueString($password"text"));
$LoginRS mysql_query($LoginRS__query$connlive) or die(mysql_error());
$loginFoundUser mysql_num_rows($LoginRS);
  if (
$loginFoundUser) {
$loginStrGroup "";
    if (
PHP_VERSION >= 5.1) {session_regenerate_id(true);} else {session_regenerate_id();}
//declare two session variables and assign them
$_SESSION['MM_Username'] = $loginUsername;
$_SESSION['MM_UserGroup'] = $loginStrGroup;
    if (isset(
$_SESSION['PrevUrl']) && false) {
$MM_redirectLoginSuccess $_SESSION['PrevUrl'];
header("Location: " $MM_redirectLoginSuccess );
  else {
header("Location: "$MM_redirectLoginFailed );
and this code from line 94 - 130:
if(WA_Auth_RulePasses("Log in success")){
    $WA_Auth_Parameter = array(
    "connection" => $connlive,
    "database" => $database_connlive,
    "tableName" => "users",
    "columns" => explode($WA_Auth_Separator,"UserEmail"),
    "columnValues" => explode($WA_Auth_Separator,"mpiasecki1@gmail.com"),
    "columnTypes" => explode($WA_Auth_Separator,"text"),
    "sessionColumns" => explode($WA_Auth_Separator,"UserID".$WA_Auth_Separator."UserEmail"),
    "sessionNames" => explode($WA_Auth_Separator,"UserID".$WA_Auth_Separator."UserEmail"),
    "successRedirect" => "userprofile.php",
    "failRedirect" => "",
    "gotoPreviousURL" => FALSE,
    "keepQueryString" => FALSE
    WA_AuthenticateUser($WA_Auth_Parameter);
if(WA_Auth_RulePasses("Logged in to users")){
    "columns" => explode($WA_Auth_Separator,"UserID"),
    "columnValues" => explode($WA_Auth_Separator,"redirect_userprifile"),
    "columnTypes" => explode($WA_Auth_Separator,"int"),
    "sessionColumns" => explode($WA_Auth_Separator,"UserID"),
    "sessionNames" => explode($WA_Auth_Separator,"UserID"),
    "keepQueryString" => TRUE
mpiasecki1437949
another problem
Thanks this did the work with this one but created another problem. Now the order is being recorded before paypal transaction. As soon as I press checkout button after entering billing information at checkout.php page the transaction is recorded and download center and customer orders are being displayed. I have attached pages.
downloadcenter_3.zip
the confirm page is posting to the paypal standard gateway, this is the way that paypal standard works.
as i outlined in the initial thread you started for this:
i dont recommend using paypal standard, you would be better of using paypal express.
mpiasecki1437949
pay pal
I changed standard to express at pay pal but didn't change confirm page. When you go thru e cart process there are only two options pay pal standard or pro no express checkout that's why those setting are still there. Is there a way to change it on the confirm page ?
no, you should delete the confirm page so it wont go through paypal standard and only use the pay with express checkout button on the checkout page.
mpiasecki1437949
pay pal
What kind of button and how to link it with pay pal express and e-card. Did anybody tried this and have the code.
mpiasecki1437949
check out
Jason,
But the transaction is recorded after checkout button at checkout page is pressed not at confirm page. This should be some error there. Even with using standard paypal this should not happen becouse confirm page redirects to paypal and not checkout. I did your suggestions with canceling the confirma page but then how to apply all these code at check out page to fill out paypal with product info etc.
