Digital File Pro some .jpg Images do not show in
Thread begun 5/10/2012 3:08 pm by elewis93815 | Last modified 5/11/2012 2:54 pm by Jason Byrnes | 2903 views | 6 replies |
elewis93815
I'm curious to know why some of my jpgs show up and some do not. I'm using Digital File Pro. I originally thought that is was my naming convention or the size of the image but doesn't seem to be the case??? I have re sized my images to 150px X
I've uploaded the image in question
This is a link to the page that I am working on: ticketbooth_Insert.php
Erick
what is the original size of the image?
most likely, either the original image exceeds the max upload file size set in the php.ini file, or the memory needed to resize the image was more than the server makes available through the memory limit setting in the php.ini file.
try adding the following code at line 1 of the insert page:
ini_set
("memory_limit""256M")
if the server has not blocked the memory limit setting, this will increase the memory limit allowed.
Where some images are uploading, but others are not, it is a server setting that is preventing them.
see the following page for details on php.ini settings that effect file upload:
wap_upload.asp?page=php2
elewis93815
Hi Jason,
What I discovered was that the image is not being uploaded to the correct directory. In the wizard I select the directory that I want the images to pull from but they are not. The wizard has the correct directory picked (visually) but is not the case.
What I've discovered is that the browse to upload an image is saving the image in the wrong directory, any advise on how to correct this would be appreciated.
Erick
ini_set
send a copy of the page please.
where do you expect the images to be uploaded?
elewis93815
The files are attached to this communication - Thanks Erick
elewis93815
any luck on figuring out this one? If possible I would like to know so that I can figure something else out, can you tell if this is a bug or something that I've done incorrectly?
Erick
I dont really have enough information
in the upload behavior, it looks like you have set the images to upload to the posters/ folder, is this correct?
where do you expect the images to be uploading to?
to help troubleshoot, edit the insert record behavior and remove the redirect, then go to the bindings panel and expand the WA Uploaded files global status binding and add the debug info binding to the page.
