Known Bugs in Data Bridge to be corrected in the next update
Thread begun 5/07/2012 8:33 am by Jason Byrnes | Last modified 2/15/2013 1:00 pm by Anna Robinson | 4683 views | 5 replies |
This is not an exhaustive list, but here are some of the known bugs we are working to correct in the next update to Data Bridge.
- Site Tools throws errors when running in CS4.
The following JavaScript error(s) occurred:
At line 150 of file "C:\Program Files (x86)\Adobe\Adobe Dreamweaver CS4\Configuration\Floaters\WA_SiteTools_ProgressV2.js":
setPreferenceInt: Argument number 3 is invalid.
-In CSS Sculptor on Windows, an error occurs if you add a spry element to the layout using the plus button on the box tab
- Units lists empty in CSS form Builder and Menu Writer
- using the preset manager edit button causes errors.
- design extender and Adobe test & Target extension cause conflicts.
- DMX Zone Compatibility
- Errors on Dreamweaver Startup regarding shared.js :
"wa is not defined."
This has been identified as being caused by having CSS Sculptor or eCart 5.0.3 installed
eCart 5.0.4 has been released to fix it, we will be relaseing a CSS Sculptor update soon.
- Errors on startup stating that floaters cannot be found:
this can be corrected by resetting the workspace layout:
Window -> Workspace Layout -> Reset 'your workspace'
- Data Assist results page missing Delete, Update and details buttons
-DataAssist > Create Pages > Search Page: Newly added columns will not have Criterion set to whatever is in the Criterion list.
-The help access points in DataAssist need to be updated to use the WAHelpReference.xml file
- Security Assist wizard crashes creating pages
- Security Assist login page is created without Server Validation
- Errors on applying the Dynamic Drop Downs populate list from array behavior.
If you encounter a problem not on this list, please start a new thread rather than replying to this one.
These issues have been addressed and an update is available in your order history now.
An email will be going out tomorrow 5/9 announcing the update.
