Remember Me not working
Thread begun 4/30/2012 6:57 pm by chssagmi366905 | Last modified 5/14/2012 8:38 am by Jason Byrnes | 4291 views | 9 replies |
chssagmi366905
I've tried to get the remember me check box to work but so far it isn't storing WA cookie.
<td><label>
<input <?php if (!(strcmp(((isset($_COOKIE["rem"]))?$_COOKIE["rem"]:""),1))) {echo "checked=\"checked\"";} ?> type="checkbox" name="rem" id="rem" />
<span class="style6">Remeber Me</span></label></td>
Is there anything here that is wrong?
imposible to tell from that code snippet, please send a copy of the entire page so i can see the code in context and a link where i can see the problem.
chssagmi366905
The link would be "http://www.reunionbusiness.com/admin/mem_login.php". I included an attachment of the page.
your page is missing the set cookie value behaviors to set cookies for the username and password if the remember me option is selected.
on the server behaviors panel, click the plus button and select WebAssist -> Cookies -> Set Cookie Value.
for the trigger and value, click the plus button and select the Remember me checkbox. set the name to "rem"
repeat this, but this time, for the value select the username element and set the name to "username"
repeat again, but this time, for the value select the password element and set the name to "password"
chssagmi366905
I still didn't quite understand so I will show the code for others to see but I also included an attachment. Thanks
<th width="28%" height="39"><span class="style4">Username</span></th>
<td width="72%"><input name="username" type="text" value="<?php echo((isset($_COOKIE["username"]))?$_COOKIE["username"]:"") ?>" size="40" maxlength="40" /></td>
</tr>
<tr>
<th height="43"><span class="style4">Password</span></th>
<td><input name="password" type="password" value="<?php echo((isset($_COOKIE["password"]))?$_COOKIE["password"]:"") ?>" size="40" maxlength="40" id="password" /></td>
</tr>
<tr>
<th height="43">&nbsp;</th>
<td><label>
<input name="rem" type="checkbox" id="rem" value="1" <?php if (!(strcmp(((isset($_COOKIE["rem"]))?$_COOKIE["rem"]:""),1))) {echo "checked=\"checked\"";} ?> />
the code you pasting is to use cookies that have been set.
the problem is that code to set the cookies does not exist.
you need to add the behaviors to set the cookies by following the instructions in my previous reply
chssagmi366905
I have done this numerous times using your help print out for remember me. Every screen is what I have done and looks the same. Can I have a support ticket please.
I have added the set cookie behaviors and it is not working, send a copy of the page so i can see the code, it is probably the trigger being used or the name of the cookie, i can probably spot the issue fairly quick if you send a copy of the page.
chssagmi366905
I hope this is what you meant. I did delete some lines that I thought you didn't need.
<?php require_once("../WA_SecurityAssist/WA_SHA1Encryption.php"); ?>
<?php require_once('../connections/dbc.php');?>
<?php require_once( "../WA_SecurityAssist/Helper_PHP.php" ); ?>
if(isset($_POST["LogIn"])){
$WA_Auth_Parameter = array(
"connection" => $dbc,
"database" => $database_dbc,
"tableName" => "tbl_users",
"columns" => explode($WA_Auth_Separator,"username".$WA_Auth_Separator."password"),
"columnValues" => explode($WA_Auth_Separator,"".((isset($_POST["username"]))?$_POST["username"]:"") ."".$WA_Auth_Separator."".WA_SHA1Encryption(((isset($_POST["password"]))?$_POST["password"]:"")) .""),
"columnTypes" => explode($WA_Auth_Separator,"text".$WA_Auth_Separator."text"),
"sessionColumns" => explode($WA_Auth_Separator,"userID".$WA_Auth_Separator."rcode"),
"sessionNames" => explode($WA_Auth_Separator,"userID".$WA_Auth_Separator."rcode"),
"successRedirect" => "../redirect.php",
"failRedirect" => "mess_loginFailed.php",
"gotoPreviousURL" => FALSE,
"keepQueryString" => TRUE
WA_AuthenticateUser($WA_Auth_Parameter);
// *** Validate request to login to this site.
if (!isset($_SESSION)) {
session_start();
$loginFormAction = $_SERVER['PHP_SELF'];
if (isset($_GET['accesscheck'])) {
$_SESSION['PrevUrl'] = $_GET['accesscheck'];
if (isset($_POST['username'])) {
$loginUsername=$_POST['username'];
$password=$_POST['password'];
$MM_fldUserAuthorization = "";
$MM_redirectLoginSuccess = "../redirect.php";
$MM_redirectLoginFailed = "mess_loginFailed.php";
$MM_redirecttoReferrer = true;
mysql_select_db($database_dbc, $dbc);
$LoginRS__query=sprintf("SELECT userID, password FROM tbl_users WHERE userID=%s AND password=%s",
GetSQLValueString($loginUsername, "int"), GetSQLValueString($password, "text"));
$LoginRS = mysql_query($LoginRS__query, $dbc) or die(mysql_error());
$loginFoundUser = mysql_num_rows($LoginRS);
if ($loginFoundUser) {
$loginStrGroup = "";
//declare two session variables and assign them
$_SESSION['MM_Username'] = $loginUsername;
$_SESSION['MM_UserGroup'] = $loginStrGroup;
if (isset($_SESSION['PrevUrl']) && true) {
$MM_redirectLoginSuccess = $_SESSION['PrevUrl'];
header("Location: " . $MM_redirectLoginSuccess );
else {
header("Location: ". $MM_redirectLoginFailed );
// start session varible
session_start();
if ((((isset($_POST["rem"]))?$_POST["rem"]:"") != "")) {
setcookie("rem", "".((isset($_POST["rem"]))?$_POST["rem"]:"") ."", time()+(60*60*24*90), "/", "", 0);
setcookie("password", "".((isset($_POST["password"]))?$_POST["password"]:"") ."", time()+(60*60*24*90), "/", "", 0);
setcookie("username", "".((isset($_POST["username"]))?$_POST["username"]:"") ."", time()+(60*60*24*90), "/", "", 0);
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
</head>
<body onload="document.WAATKLogInForm.username.focus()">
<div id="container">
<div id="header">
<h2 align="center"><strong>Member Login</strong></h2>
</div>
<form ACTION="<?php echo $loginFormAction; ?>" method="POST" name="WAATKLogInForm" id="WAATKLogInForm">
<table width="55%" border="0" align="center" cellpadding="5" cellspacing="0" class="WAATKDataTable">
<tr>
</tr>
<tr>
</tr>
<tr>
<td><label>
<input name="rem" type="checkbox" id="rem" <?php if (!(strcmp(((isset($_COOKIE["rem"]))?$_COOKIE["rem"]:""),1))) {echo "checked=\"checked\"";} ?> />
</tr>
<tr>
<td><a href="forgot_password.php"><span class="style4"><strong>Forgot Password</strong></span></a></td>
</tr>
</table>
<p>&nbsp;</p>
<div align="center">
<input type="Submit" name="LogIn" id="LogIn" value="Log In">
</div>
</form>
<p>&nbsp;</p>
<table width="25%" border="1" align="center" cellpadding="5">
<tr>
<td><label> </label>
<input name="redirect" type="button" id="redirect" onClick="MM_goToURL('plugins/parent','../redirect.php');return document.MM_returnValue" value="Homepage">
</div></td>
</tr>
</table>
</div>
</body>
</html>
the set cookie code:
needs to be moved to line 1 of the page.
