Clear cart clears everything or nothing
Thread began 4/30/2012 5:41 pm by rgolab68503 | Last modified 5/01/2012 6:47 pm by rgolab68503 | 197 views | 4 replies |
rgolab68503
When I add the clear session values to my page I can get it to clear everything by checking the box to "clear all sessions". However, if I select only the cart items in the window nothing gets cleared.
When looking through the forums i came across a similar issue and tried adding the suggestions to save and and restore so my code now looks like this.
$loginUsername = $_SESSION['user_name'];
$password = $_SESSION['pass_word']
@session_start();
if ("" == ""){
// WA_ClearSession
$clearAll = TRUE;
$clearThese = explode(",","");
if($clearAll){
foreach ($_SESSION as $key => $value){
unset($_SESSION[$key]);
else{
foreach($clearThese as $value){
unset($_SESSION[$value]);
<?php session_start();
$_SESSION['user_name'] = $loginUsername;
$_SESSION['pass_word'] = $password;
This however still logs me out. Am I missing something in the restoring of the username and password?
I tried simply using the clear cart function before page load but it just stalls the page for some reason.
// WA eCart Trigger Clear Cart
if ("" == "") {
$ToyoeCart->ClearCart();
$Redirect_redirStr="checkout_success.php";
if ($Redirect_redirStr != "") {
$ToyoeCart->redirStr = $Redirect_redirStr;
$ToyoeCart->cartAction = "ClearCart";
// WA eCart Redirect
if ($ToyoeCart->redirStr != "") {
header("Location: ".$ToyoeCart->redirStr);
Ideally what it needs to do is clear the cart however not clear the log in session variables so the visitor can continue to do other activities.
that first code should work for clearing the cart but leaving the user logged in, if it is not leaving the user logged in, there must be another session variable that is used by the login system.
to help troubleshoot, lets take a look at the login system. After login, what page is the user redirected to? Open that p[age and add the following code just after the <body> tag to write the session contents:
<pre><?php var_dump($_SESSION); ?></pre>
I'm guessing that in addition to the username and user password session variable, there is a use ID session that needs to be reset as well.
rgolab68503
Log out clearing cart
Hi Jason,
Thanks for your help and your patience. I am getting closer. It is now clearing the cart properly which is great and it leaves or keeps the login session going but somehow i need to pick up the password. If we simply user the username it is picking up the first "Ron" in the list and logging in as them. It doesn't seem to catch the other two session variables.
// Initialize the session.
// If you are using session_name("something"), don't forget it now!
@session_start();
//store the user session
$userSession = $_SESSION['MM_Username'];
$userSession = $_SESSION['pass_word'];
$userSession = $_SESSION['user_name'];
// Unset all of the session variables.
$_SESSION = array();
// If it's desired to kill the session, also delete the session cookie.
// Note: This will destroy the session, and not just the session data!
if (ini_get("session.use_cookies")) {
$params = session_get_cookie_params();
@setcookie(session_name(), '', time() - 42000,
$params["path"], $params["domain"],
$params["secure"], $params["httponly"]
// Finally, destroy the session.
session_destroy();
unset($_SESSION);
session_start();
session_regenerate_id();
//reset user session
$_SESSION['MM_Username'] = $userSession;
$_SESSION['pass_word'] = $userSession;
$_SESSION['user_name'] = $userSession;
Per you code here are the session variables when I initially log in ...
<pre>array(4) {
["MM_Username"]=>
string(3) "ron"
["MM_UserGroup"]=>
string(0) ""
["pass_word"]=>
string(8) "changed"
["user_name"]=>
string(3) "ron"
</pre>
This is what happens when I order something on the cart and checkout ...
<pre>array(4) {
["MM_Username"]=>
string(3) "ron"
["MM_UserGroup"]=>
string(3) "ron"
["pass_word"]=>
string(3) "ron"
["user_name"]=>
string(3) "ron"
</pre>
all the sessions switch to username Ron. I am not storing the sessions properly?
Any suggestions?
you are using the same variable name for each session:
at the end of the day $userSession is now equal to $_SESSION['user_name'] and there is no variable that contains the others, you need to use a unique variable name for each one:
$MM_Username = $_SESSION['MM_Username'];
$pass_word = $_SESSION['pass_word'];
$user_name = $_SESSION['user_name'];
and make sure to use the correct variable when resetting the sessions.
$_SESSION['MM_Username'] = $MM_Username;
$_SESSION['pass_word'] = $pass_word;
$_SESSION['user_name'] = $user_name;
rgolab68503
Clearing cart and logging out
Oops, I completely missed that part. Thanks for sending me in teh right direction. i switched it to:
@session_start();
session_destroy();
unset($_SESSION);
session_start();
and it works perfectly.
