Powerstore vs Dreamweaver CS4 + Supersuite
Thread begun 4/29/2012 4:52 am by stephen433416 | Last modified 5/03/2012 12:33 am by stephen433416 | 1350 views | 2 replies |
stephen433416
Hi, I currently have Dreamweaver CS4, Supersuite and Powerstore. I have been using Powerstore to set up a product catalogue online. I would like to modify some of the design template layouts and features (some examples listed below)
1. Modify the product detail page layout
2. Have more than one product detail page layout for display (depending on the type of product. (eg some with pricing and some without)
3. Add the term “Ex GST” to the pricing
4. Reduced the tab space on the left hand submenus
Am I better off still using Powerstore and making the modifications I need (if possible), or should I just use the database I have built and create a new dynamic website with CS4 + Supersuite?
I am using Powerstore with the hope that it will save time but I am worried that I might be going down the wrong path.
Kind regards Stephen
I'd recommend using powerstore as a starting point and then making the necessary adjustments and additions using the tools.
There is a lot of work that went into powerstore, so I'm sure it would be less work to climb the learning curve to understand how powerstore works add the few things you need than to recreate the entire store.
stephen433416
Ok I will do just that. Thanks for the advice.
