PG & jQuery Lightbox on same page playing issues
Thread began 4/28/2012 2:57 am by a2d | Last modified 4/28/2012 9:30 pm by Jason Byrnes | 411 views | 1 replies |
a2d
I am working on a site with a link to a youtube video using jQuery Lightbox on the bottom. It works fine and pops open on all pages (like PG pops open) except the Gallery page that I have a php code added using the PG. When this happens it does not allow jQuery to pop open. It just goes to the youtube page rather than pop open like on all other pages.
Anyone know a fix?
Ernie
really depends on the type of gallery you are using.
some of the galleries use mootools, and some of them use jquery.
If you are using a jquery gallery, it is most likely that your jquery script is using a different version.
if you are using a mootols gallery type, then you will need to configure your jquery script to use compatibility mode:
Using_jQuery_with_Other_Libraries
the issue being that both jquery and mootools create a $ function allowing you to reference elements by ID: $("elementID"). if using both libraries at the same time, only one can use the $ function.
