Dynamic Plug ins gives invalid code and doesn't work?
Thread begun 4/09/2012 10:30 am by Brad Lawryk | Last modified 4/09/2012 11:50 am by Brad Lawryk | 1466 views | 2 replies |
Brad Lawryk
Hi guys, for some reason I have a site that I cannot add Dynamic plug ins to?
I have attached screen shots of the UI, the resulting code and a zip file of a sample page.
They show more than what I can explain.
for the server variable, you are adding a static string:
pageView
which is not a variable name, variable name must begin with "$":
$pageView
however, that would be a local variable and would need to be defined on the page before the dynamic plugin code.
you should probably be using a URL variable:
$_GET['pageView']
or session variable:
$_SESSION['pageView']
Brad Lawryk
Yeah thanks, figured it out. Brain dead today. Just came back to post not to woory I got it working.
Thanks again!
