Will not accept captcha code
Thread began 3/28/2012 10:17 pm by bryan107833 | Last modified 3/29/2012 11:24 am by Jason Byrnes | 633 views | 3 replies |
bryan107833
I have at least two sites in which the Captcha Image will not accept and you just get stuck on "Your security code entry did not match the image." Both of these sites did work and I can not find where the problem is. Ideas? I have attached one of the contact pages.
contact.zip
First, I would test the servers session management to make sure it is saving session information corrcetly using the session test page here:
showpost.php?p=23826&postcount=2
if the session test fails, it is most likely a bad setting in the PHP.ini file for the session.save_path, your host will need to correct that.
if the session test passes, to help troubleshoot, find the following code:
if ($WAFV_Errors != "")  {
    PostResult($WAFV_Redirect,$WAFV_Errors,"contact");
and change it to:
    die($WAFV_Errors."<br><pre>".var_dump($_POST)."</pre><br><pre>".var_dump($_SESSION)."</pre>");
this will write the session contents and post contents to the screen when validation fails to help find the cause of the problem.
bryan107833
If I am reading this correctly, when the form post it is getting a new captcha image.
array(15) { ["Contact_Name"]=> string(5) "Bryan" ["addblock"]=> string(0) "" ["Email_address"]=> string(28) "bryan@xxx.com" ["seconddblock"]=> string(0) "" ["Phone"]=> string(0) "" ["preferred"]=> string(10) "Choose one" ["Mailing_Address"]=> string(0) "" ["City"]=> string(0) "" ["State"]=> string(0) "" ["Zip"]=> string(0) "" ["Hear"]=> string(0) "" ["Comments"]=> string(14) "test webassist" ["Security_code"]=> string(5) "h6MzN" ["Security_imagebutton_x"]=> string(2) "59" ["Security_imagebutton_y"]=> string(2) "13" } array(2) { ["captcha_1"]=> &string(5) "999ZK" ["WAVT_contact_Errors"]=> string(0) "" } ,4
