Search function using multiple checkboxes
Thread begun 3/15/2012 12:53 pm by eric284736 | Last modified 3/21/2012 9:05 am by Jason Byrnes | 11498 views | 10 replies |
eric284736
I want to setup a search function where each search variable will have chechboxes and the user could select one or more checkboxes for each varaible.
Example:
1. Country - France (checkbox) Italy (checkbox) Any(checkbox)
2. Region - Paris(checkbox) Corse(checkbox) Sicily(checkbox) Any(checkbox)
3. Search For - Rental(checkbox) Sale(checkbox) Any(checkbox)
4. Property Type - Home(checkbox) Apartment(checkbox) Any(checkbox)
For the Any checkbox I would want it to return any or all of the records under that variable.
I am just not sure what that value would be to return "any" unspecified record for that search variable.
Can this be done with the Search function?
Thx!
Eric
yes, this can be done using the data assist search wizard and modifying the search form after it is created.
in the data assist search wizard, add the criteria for each of the columns to use a checkbox, and use the keyword search type.
after the form is created, you will need to add the additional checkboxes for the additional choices.
for example, the from will add the country checkbox as:
<input type="checkbox" name="country" value="country" />
you will need to change that to:
France: <input type="checkbox" name="country[]" value="france" />
Italy:<input type="checkbox" name="country[]" value="Italy" />
Any: <input type="checkbox" name="country[]" value="" />
same for the other column, change the name to include "[]" at the end and set the value for the any option to be blank.
then add the following code at line 1 of the results page:
if($_SERVER["REQUEST_METHOD"] == "POST")     {
    foreach(
$_POST as $key => $val) {
        if(
is_array($_POST[$key])) $_POST[$key] = implode(" "$_POST[$key]);
eric284736
Excellent!! Thanks Jason!
eric284736
Hi Jason,
Okay I have a search form in place and a results page. Here is the Results code:
foreach($_POST as $key => $val) {
if(is_array($_POST[$key])) $_POST[$key] = implode(" ", $_POST[$key]);
<?php require_once('Connections/connBLUR.php'); ?>
//WA Database Search Include
require_once("WADbSearch/HelperPHP.php");
//WA Database Search (Copyright 2005, WebAssist.com)
//Recordset: rsProp;
//Searchpage: 0test.php;
//Form: form1;
$WADbSearch1_DefaultWhere = "";
if ((isset($_POST["WADbSearch1"])) && ($_POST["WADbSearch1"] != "")) {
$WADbSearch1 = new FilterDef;
$WADbSearch1->initializeQueryBuilder("MYSQL","1");
//keyword array declarations
$KeyArr1 = array("Country");
//comparison list additions
$WADbSearch1->keywordComparison($KeyArr1,"".$row_rsProp['Country'] ."","AND","=","%20AND%20","%20OR%20","%22","%22",0);
//save the query in a session variable
if (1 == 1) {
$_SESSION["WADbSearch1_resultsTEST"]=$WADbSearch1->whereClause;
else {
//get the filter definition from a session variable
if (1 == 1) {
if (isset($_SESSION["WADbSearch1_resultsTEST"]) && $_SESSION["WADbSearch1_resultsTEST"] != "") {
$WADbSearch1->whereClause = $_SESSION["WADbSearch1_resultsTEST"];
else {
$WADbSearch1->whereClause = $WADbSearch1_DefaultWhere;
else {
$WADbSearch1->whereClause = str_replace("\\''", "''", $WADbSearch1->whereClause);
$WADbSearch1whereClause = '';
Here is the search form:
<form name="form1" action="resultsTEST.php" method="post">
<table cellpadding="2" cellspacing="0" border="0">
<tr>
<td width="37" align="right"><label for="Country">Select</label></td>
<td width="200"><input type="checkbox" name="Country[]" value="" />
Any
<input type="checkbox" name="Country[]" value="France" />
France
<input type="checkbox" name="Country[]" value="Italy" />
Italy</td>
</tr>
<tr>
<td align="center" colspan="2"><p>
<input type="submit" name="WADbSearch1" value="Submit" />
</p>
<p>test </p></td>
</tr>
</table>
</form>
What I am not sure about on the search parameter is what the VALUE should be after the Type.
Thx
Eric
for the value, click the lightning bolt icon and select the country form element.
info22862
Can this be done using multiple tables.
I have been attempting to create a similar function.
Basically search for a business profile based on selected check boxes/Radio buttons and drop down lists. However, in my case I have the data in distinct tables.
IE: One table holds the company contact data, another holds the courses they offer.
I want to find all matching companies to the search query, then display each company using repeat record set. The issue I run into, is when trying to display the company I can only display one course they offer, I am not able to select multiple rows from the courses table that match.
I don't expect the pro's like Jason to solve this for me, however if you could enlighten me if this is even possible it would be a great help. I have read that WA is not able to work with multiple tables using DataAssist.
If there is a PHP / MySQL expert who would like to take this on as a side project, educate me and solve the search issue, I would love to outsource it to you.
Thanks in advance - Jerry
you need to edit the recordset so that it uses a join query to return related data from both tables.
you don't go into to much detail on how the relationship of the 2 tables is created, so i can give an example of the query, but you can find more details on join queries here:
sql_join.asp
info22862
Thank you Jason, I'm no MySQL pro for sure, this is my basic structure.
Each Table has a clientid associated with it to help with joins.
states.clientid (states offering services in - multiple rows)
clients.clientid (client contact info - single row)
languages.clientid (languages spoken- multiple rows)
courses.clientid (courses offered- multiple rows)
Select *
where
(formstate=states.statesid and states.clientid=clientsid)
and formlanguages=languages.languagesid
and formcourses=courses.courseid
Results page:
client company
course1
course2
course3
Language 1
language 2
language 3
Repeat recordset to display all matching results.
I don't expect you to crack this nut for me, but perhaps this additional detail will clarify things. I will read up on joins.
Thanks again - Jerry
eric284736
Hi Jason,
I did that but it list the 3 checkboxes as country[].
Here are the pages searchtest.php
and if you select France or Italy it shows all the countries.
Let me go back a couple of steps and ask this: When I run the search wizard should I use the single checkbox form element OR the multiple select or checkboxes form element?
thx
Eric
eric284736
Jason, here are the zipped test pages.
thx
Eric
