Add Image in the menu
Thread begun 1/18/2012 12:50 pm by info427536 | Last modified 1/19/2012 9:25 am by Jason Byrnes | 2674 views | 6 replies |
info427536
How can you add an image in the main menu and should be the dimensions
you would need to edit the webassist/plugins/main_menu/menu.php file and add an inline style for the background image, for example:
change:
<li class="top"><span><a href="../../../index.php">Home</a></span></li>
to:
<li class="top"><span><a href="../../../index.php" style="background-image: url('plugins/path/to/image.jpg');">Home</a></span></li>
the dimensions will change from theme to theme, 90 X 35 is a good starting point though
ARLEY_BARLEY434768
i agree too
i agree <li class="top"><span><a href="../../../index.php" style="background-image: url('plugins/path/to/image.jpg');">Home</a></span></li>
info427536
Menu
Does that mean I will be able to set the height from 55 to 40px of navigation as well, when I do that the banner underneath floats to the right.
Also do I add the image to the index.php file or the css
you need to edit the theme css to change the height of the navigation, not the menu file.
send a link to your site and i can give more information
for the image on the menu, by adding the inline style:
to the menu item, you are attaching the image to the menu, you don't need to add it anywhere else.
info427536
website
www.buyclearancefurniture.co.uk
in the webassist/themes/three_col_new/css/crazy_styles.css file, you need to edit the height of the #navWrapper selector, and the height and line-height for the #cssmw li.top selector to change the menu items height.
