Using URL to post to Results Page
Thread began 7/19/2009 10:35 am by mcriecken380554 | Last modified 8/11/2009 7:50 am by Ray Borduin | 7243 views | 14 replies |
mcriecken380554
On my main page I have a navigation bar with a menu that lists different types of my inventory. I'm trying to get it to work so that when a user clicks on a type in the list, it will post to the results page with only that type. Here is the code I have in the URL link.
My_Results.php?type=Car
This brings up the results page fine, but it's showing all of my results instead of filtering out just those of a certain type. The field in my table is named type.
You would either have to add a parameter to the Recordset or apply DataAssist search in order to actually filter the results based on the passed url parameter.
mcriecken380554
Question
Can anyone shed a little light on this for me? I'm not quite sure how to add a parameter like this to the recordset. I've already applied Data Assist Search Wizard to My_Results.php and created a search page. Basically, I'm wanting to have a list of categories on my main page that are each individual links to specific categories. I'm guessing I need to add a method to the results page to get the information on the results page? But I'm not quite sure how to go about doing that. Thanks in advance.
-Matt
Edit the recordset on the results page and add a filter using the interface provided.
Does your search page already have a category search option? If so you don't even have to edit the recordset, just mimic the url that the search page creates when doing a category search.
mcriecken380554
Filter
I added the filter to sort using a URL variable of Type. This allows my URL links to work just fine, however, with this filter active none of my other value searches will work. I've tried creating two different databases, one with a filter and one without, but this didn't work. When I take the filter off, my regular search functions work just fine. I do not have a menu search option to search by type, I am only wanting to create URL links to display certain type results. Thanks for all of your help.
-Matt
How did you do your other value searches? I doubt two databases is the way to go. It is difficult to give advice without a deeper understanding of what exactly you are doing and how it is working now.
mcriecken380554
Filter
Here is an idea of what I'm trying to do. The page is a little messy, but this should give you an idea.
My_Search.php
Basically, I have the search fields as the main part of the search page. If you mouse over 'inventory' in the menu bar, it lists different types of autos. Ideally, when these different types are clicked I'd like the results page to display only the corresponding type. The problem I'm running into is that when I add the filter to the recordset (by double-clicking the recordset in the bindings panel), this causes my main search fields to stop working.
How did you do the original search feature? If you use dataAssist search in a current version for that, and a url parameter for the menu as you describe, it should work as you expect. I see it isn't working, so it has to be an issue with the original search implementation or the trigger in your dataAssist search server behavior.
mcriecken380554
Filter
I think perhaps I'm just adding the filter incorrectly. I just redid my pages and applied a fresh DataAssist Search Wizard. Under the Server Behaviors panel I see the DataAssist Search that is used for all of my search functions. Do I need to edit the one already made? I'm confused because if I just double click on the recordset, and apply a filter for "Type", my links work just fine, but this causes my other search functions to stop working.
