Invalid File Type
Thread begun 7/19/2009 6:11 am by web_assist_mail157665 | Last modified 7/20/2009 8:39 am by Ray Borduin | 2496 views | 2 replies |
Invalid File Type
When iRite first came out - I added to one of my sites.
I recently went back to the site and tried to upload some small images and files
The site works fine locally
the remote FCK config seems fine
but when I try to upload an image on the remote server, I get...
"Invalid File Type"
ANY reason why I should be getting this on the server and NOT locally
File sizes are easily under the limit and of correct extension, with no strange characters in file names. Permissions are correct - running out of things the check
Could something have been changed on the server???
my supplier has changed some setting that have caused 'no tmp folder found' errors before
FYI
phpinfo says
php ver 4.4.9
open_basedir /home/(edited:myuserrefhere)/:/tmp:/usr/local/lib/php
Originally Said By: web_assist_mail157665
FYI
phpinfo says
php ver 4.4.9
Ah - looks like its a combinations of things
according to my supplier
PHP open_basedir setting for this particular url needs to be set to "no value"
or
use a more up to date version of FCK, which resolves the problem
Can you guys confirm this is the case?
It sounds likely to be true. I would tend to believe them.
