Powerstore menu & design questions
Thread began 10/02/2011 8:08 pm by wdlis357973 | Last modified 10/03/2011 8:42 am by Jason Byrnes | 1150 views | 1 replies |
wdlis357973
I am still working on the design, I edited the home page with DWcs4.
I am using the "purple" theme.
index.php
I still have some problems:
1.The "support: menu item got deleted and I can't get it back.
2. In the "footer" I can't change the "Terms of use" I would like to put "store policies"
3. how can I take out the border around the products.
4. How can I make the subdirectory of the nemu wider.
5. How can I make the "product's font, short and detailed description" larger
Alisa
1) Try running the sql script from the following thread to recreate the cms contents for the support menu:
showpost.php?p=89123&postcount=4
2) In the content management, select the Footer Pages - Terms Of Use content atrea and edit the header to whatever you would like to replace it with.
3) I dont see any border around products on your page, please provide a screen shot showing what you would like to change.
4) in the powerstore/webassist/themes/Bananatree/css/purple_styles.css file, cheange the width of the #cssmw li a selector
5) in the powerstore/webassist/themes/Bananatree/css/configurable.css edit the size for the h2 selector to change the product font. the description font size is set in the content management in the admin panel. you may need to set the HTML Editor instance for the description into Source mode to see the font size setting.
