User email password not being sent
I have been trying to trouble shoot why my random email password is not being sent. I found the following threads:
1) showthread.php?t=21673&highlight=email+password
On the thread above you recommended the following,
"the code for the trigger is set for an image button type, but this page uses a standard submit button.
open the server behaviors panel, double click the email password server behavior and reset the trigger. "
I made my trigger to--> Button: Send pressed
Random password email does get send.
The following thread
2) showthread.php?t=19905&highlight=email+password
You said, "on the go to page, add the following code just after the body tag:
<pre><?php var_dump($_SESSION); ?></pre>"
I did that and still no email was sent. The only lines that I received on the got to page were the following:
array(1) {
["newPW"]=>
&string(9) "oB6F0KBDM"
I also used port 25 and port 587 but no luck. Did I miss something?
I also would like to add that the WIZARD forgot to add the session variable "newPW" in"sessionVariables" => array(""). I added the variable thinking that could the problem but I realized that sessionVariables is where the random password gets store when sending the email to the regirested user.
My stmp server is smtpauth.earthlink.net. Please do not say that there could be an issue with earthlink's smtp server because I have created a page sends email without any problem.
