Auto Login / Remember me
Thread begun 7/12/2009 4:23 am by John Langer | Last modified 7/17/2009 1:01 pm by John Langer | 7480 views | 8 replies |
John LangerBeta Tester
I've already set up the Security Assist LogIn features and it's all working perfectly.
The client would now like the Auto Login and Remember me features added.
1. What's the difference between the two? Does having both on the page add anything security / convenience wise?
2. How easy is it to add these functionalities to an existing login page? Is there a tutorial somewhere or a help file? I have searched for an answer but can't seem to find it. I don't really want to have to start again with the wizard.
Many thanks,
1) Remember me sets cookies with username and password values and pre-populates the two fields. Auto login will check if the cookies exist and will log you in and skip the login page entirely. Remember me is required for Autologin to work and not the other way around.
2) You use cookies toolkit to set the cookies and set the initial values of the form elements from the cookies, and then you apply the login server behavior a second time on the page with the same settings as the first only using the cookie values for the username, password, and trigger... maybe run the wizard again on another page and look at what it does as a sample.
Thanks Ray, you've explained it beautifully.
I like the suggestion of running the wizard on another page to get the examples. Why didn't I think of that? :-)
Many thanks.
Hi Ray,
Just thought I'd update this to say that it worked like a dream.
Many thanks.
roywurgley382617
John,
if possible could I see the site you have put a registeration and login on, I am looking into purchase but would like to see live, instead of on wa site, and you seem happy with the performace of this, correct? Thx
Hi Roy,
I haven't done a registration page but here is the login page if it helps
I'd certainly recommend buying this extension. It's brilliant as are all of WebAssists extensions.
The real beauty is that if you get stuck they are always more than willing to help.
roywurgley382617
thx John, you helped make up my mind to purchase, I think you use to hang out at community mx?
roywurgley382617
John, forgot to ask you what all products do you have from WA, thx Roy
Hi Roy,
Good decision.
Yes I hang out at CMX. aka John E
I think I have all extensions apart from Dynamic Web Charts.
