Dynamic Web Charts on CS5.5?
Thread begun 8/01/2011 11:43 am by theo373559 | Last modified 9/07/2011 6:44 am by Jason Byrnes | 4589 views | 5 replies |
theo373559
Hello,
I upgraded to CS5.5 without realizing that WebAssist's extensions were not yet compatible with this release. I planned on using Dynamic Web Charts to create dynamic graphics on elements of my website, but any attempt to run the extension crashes Dreamweaver. As I thought it was a configuration problem, I have tried the usual solutions of clearing cache, deleting the config file, and reinstalling the plugin. Then I re-checked the WA site and realized the plugin isn't explicitly compatible with CS5.5.
Does anyone have suggestions on how I might get this extension to work without downgrading my suite version? I'm open to a little creativity here...
Thanks!
georgevargasa302189
I had a similar problem when I recently purchased this extension, and I am using CS5.5.
I resolved it by manually uploading the DynamicWebCharts folder to the remote server.
double check your Dreamweaver site settings and make sure you have a testing server configured, if you only use a remote server, set the remote server to be both remote and the testing server.
toms016390756
Originally Said By: georgevargasa302189
I did the same
anonymous
I cannot get it to work either... I am curious if it is a combination of CS5.5 and OSX Lion. Not sure, but it constantly crashes Dreamweaver.
Best regards,
Brian
