Replace Existing File during Update
Thread began 7/27/2011 11:29 am by codamedia | Last modified 12/23/2011 7:40 am by steelace396915 | 1659 views | 2 replies |
codamedia
I have DataAssist setup with File Uploads on Insert and Update. Everything is working fine in that regard. I have my uploads set to "Replace" a file if that file name already exists, and this is working as expected.
But, during an update is there any way to remove the old file when the name is different so it no longer consumes space?
Example:
1: I upload file "AAA.jpg" as my default profile image. The file uploads, and the name is stored in the DB field.
2: During an update, I upload image "BBB.jpg" to change my profile image. BBB.jpg is uploaded, and the new filename is replacing the old filename name in the DB field. So far - so good as the database references the correct image.
The problem is - Now I am left with both "AAA.jpg" and "BBB.jpg" on the server. The database only references "BBB.jpg" so "AAA.jpg" is doing nothing but taking up space.
codamedia
SOLVED!
I found the way to do this by using the delete file field, and setting the trigger to "upload filename_here successful" then providing the appropriate key bindings.
All is good!
steelace396915
Great! Ive banged my head trying to do this! Not for too long though! ;=)
Thanks!
Regards,
Martin J.
