PS 4.5 Admin area themes edit error
When admin attempts to edit an existing theme the user is getting this error:
Warning: fopen(../../themes/temp_editing/css/configurable.css) [function.fopen]: failed to open stream: No such file or directory in /home/content/58/8127658/html/webassist/plugins/styler/styler.php on line 98
Warning: filesize() [function.filesize]: stat failed for ../../themes/temp_editing/css/configurable.css in /home/content/58/8127658/html/webassist/plugins/styler/styler.php on line 99
Warning: fread(): supplied argument is not a valid stream resource in /home/content/58/8127658/html/webassist/plugins/styler/styler.php on line 99
Warning: fclose(): supplied argument is not a valid stream resource in /home/content/58/8127658/html/webassist/plugins/styler/styler.php on line 100
Warning: simplexml_load_file() [function.simplexml-load-file]: I/O warning : failed to load external entity "../../themes/temp_editing/theme_settings.xml" in /home/content/58/8127658/html/webassist/plugins/styler/styler.php on line 103
Fatal error: Call to a member function asXML() on a non-object in /home/content/58/8127658/html/webassist/plugins/styler/styler.php on line 116
