Unix Timestamp to dd-mm-yyyy
Thread begun 7/09/2011 8:32 pm by neilo | Last modified 7/11/2011 12:57 pm by Jason Byrnes | 7168 views | 8 replies |
neilo
I have a recordset from which I query:
$query_rs_data = "SELECT time_last_run FROM phpmysqlautobackup";
which I use to output a Date:
<?php echo $row_rs_data['time_last_run']; ?>
The 'time_last_run' value is a Unix timestamp, i.e: 1310250618 (seconds from start of Unix epoch).
How can I output this to page as dd/mm/yyyy instead of 1310250618 (without it outputting 1st Jan 1970).
Help appreciated.
neilo
Thanks Dave
Thanks to Dave Buchholz (yet again) whose post I found Here
So for my example above, it was:
$query_rs_data = "SELECT DATE_FORMAT(DATE_ADD(FROM_UNIXTIME(0), INTERVAL time_last_run SECOND), '%b %d %Y %h:%i %p') As LASTRUN FROM phpmysqlautobackup";
and
<?php echo $row_rs_pg['LASTRUN']; ?>
which output: Jul 09 2011 11:34 PM
Perfect. Cheers Dave.
just to keep your options open, another way to accomplish this is using the php date function:
example:
<?php echo(date("d/m/Y"$row_rs_data['time_last_run'])); ?>
neilo
Hi Jason,
Thanks, - I tried this (as is, and in variations thereof) but this kept returning 01/01/1970.
perhaps try:
<?php echo(date("d/m/Y"strtotime($row_rs_data['time_last_run']))); ?>
neilo
Yes, I'd have thought that would do it, but it still returned 01/01/1970
Just echoing the value; <?php echo $row_rs_test['time_last_run']; ?>
returns the unix date (in seconds from Unix beginning date): 1310250898
Using the regular php date functions doesn't seem to increment this value on to the Unix (epoch start) date and print it as a recognizable date format.
not at all sure what the problem may be.
This code, for me:
<?php echo(date("d/m/Y", "1310250618")); ?>
returns:
09/07/2011
neilo
The problem is the same one that keeps cropping up, i.e. - me.
Running it again on a fresh test page (with recordset rs_test) with your first code:
<?php echo(date("d/m/Y", $row_rs_test['time_last_run'])); ?>
Returns the date just fine. I now need to back-track and see how I messed up the first time.
I think it is my destiny to make others feel better about themselves and their abilities by displaying my ignorance on these pages. Thanks for helping out - sorry to have wasted your time again,
n.
No worries, glad to hear you got it working.
