captcha accepts any text
Thread begun 7/06/2011 7:21 am by CraigR | Last modified 7/06/2011 8:56 am by CraigR | 2600 views | 4 replies |
CraigRBeta Tester
just designed a simple form.
I find if the captcha response is left blank, an error prompt occurs, but any text entered into the field is accepted
contact2.php
send a copy of the page please so i can see the code.
CraigRBeta Tester
ok, file is attached
there is no server validation on this page.
the server validation to validate the captcha has not been added.
Go to Webassist > Forms -> Validation -> Server Validation.
for the validation type, select Like Entry, click the lightning bolt next to server variable and select the Security_Code form element, when prompted to select the comparison element, select the captcha_Security_Code_1 session variable.
CraigRBeta Tester
Ok, I will check that out, i thought that maybe the form designer wizard would have done this part
