Dynamic Nested Menu help
I’m having a problem using the css menu writer, in creating a dynamic nested level 2 menu.
- I’ve created a dynamic level 1 no probs (from table nav1)
- I’ve added a dynamic level 2 menu, but without any filtering (from table nav2)
... all rollovers show all sub-menu links (I expected this to happen - due to no filtering)
- but when I try and use the ‘nesting’ function for the level 2 menu nothing appears in level 2
I have thoroughly read the help notes as well as the forums. Over the years I’ve got a good feel as to how to edit the webassist wizards as well as where to find raw source code to make unusual additional edits; as such I have gone into the menu.php file and tested the recordset (within dreamweaver) by changing the default value, the recordset test does populate correctly.
I’ve attached a screen print of the wizard conf pages
My tables are:
Table 1 nav1: id, text1, link1
Table 2 nav2: id, text1, link1, page1 .... (page1 is the nav1.id ... ie the parent ID)
id is the unique key field in both tables.
- I have tested my example by including a ‘did’ database field ie DynamicmenuID and populating etc
- but still get no 2nd menu, so I don’t think using ‘id’ is an issue
The field ‘page1’ is effectively the parent id
- ie the same id number as the relevant nav1.id .... nav1.id = nav2.page1
The text1 is the navigation Name, link1 is the page to link to.
Both tables also have fields called 'pos' for position 'nl' navlist online 0 or 1, but these field aren't included in getting the basic information to display. Once basic display is working additional filtered will be added by editing the menu.php outside of the wizard.
nathan
