File path?
Thread began 6/26/2011 5:07 am by Remco209061 | Last modified 6/30/2011 1:31 pm by Jason Byrnes | 2516 views | 9 replies |
Remco209061
File path?
Hello
Can someone tell me how to change image path.
if I Place an image in the conentent the image path is wrong.
it must be: ../../Nieuws/afbeelingen/test.jpg
but I get: / A&S/Nieuws/afbeelingen/test.jpg
I'm using: HTML Editor 2.x Current version: 2.0.2
On a mac with OSX 10.6.7
grts Remco
the upload file path is set in the HTMLEditor/Editor/Filemanager/Connectors/php/config.php file
Send a copy of that file so i can see how it is set up to help fix the problem.
Remco209061
Hello Jason,
see the attachment please.
I used the editor before for other site's an never had this problem.
grts Remco
config.txt
Remco209061
Hi Jason
I changed these
$WA_EditorLocalRoot = '/A&S/';
$WA_EditorRemoteRoot = '/A&S/';
into
$WA_EditorLocalRoot = '';
$WA_EditorRemoteRoot = '';
But it won't work! The path stay's wrong.
grts
Remco209061
Is this solved in 3? Then I try that.
grts Remco
yes, it should be fixed in HTML Editor 3
Remco209061
HTML Editor 3
Hello Jason,
does it also work in DW 5.5? and can I use CSFormbuilder 201_Beta?
Remco209061
problem solved HTML 2
Hello Jason,
the problem is solved when you change the settings in the {HTMLEditor/editor/plugins/kmf/configuration.php)
line 19 and 20 see screendump!
ok, glad to hear you found the solution.
