Change Text Style
Thread began 5/12/2011 11:23 am by info4753 | Last modified 5/14/2011 12:56 pm by neilo | 517 views | 3 replies |
info4753
Change Text Style
How can I change the text style of for example a menu field? The only way to do this (for what I found) is changing the CSS "by hand".
In the Edit Form Design section, select Form Elements from the initial drop down list, then select the type of form element you want to edit.
info4753
I can't find a possibility to change the font from italic to normal. Screenshot attached.
neilo
There isn't that option (that I can see).
Just select the menu item in Dreamweaver design view, and in the css styles panel > Add Property > font-style > italic
