Validation not working & 1 field is missing in the email.
Thread began 5/10/2011 12:37 pm by paulp123370 | Last modified 5/16/2011 2:55 pm by paulp123370 | 1087 views | 14 replies |
paulp123370
Hello,
2 Problems.
1. I cannot get the validation to work properly for the text_areas (I'm trying to make it so that the entry length for the text_areas are 1 Char Min and 300 Char Max).
2. The first text_area field ("Significant Changes....") results do not show up in the email.
All of the files are attached and I've included a notepad file with the webaddress to the current online form.
Could I please have some assistance with this.
Thank you!
paul_p_files.zip
both problems are caused by invalid form element names.
form element names must conform to the following rules:
1) You can only use letters and numbers, the only exception is the underscore "_" character. Spaces are not allowed
2) The first character in the name must be a letter.
your from element names contains spaces which is causing the problem with validation and causing them to be dropped from the email.
paulp123370
I will make the appropriate changes and update you. Thanks for the quick response.
you're welcome.
paulp123370
still some issues
Made the changes to the form, saved the form as a template, and then started from scratch by importing it into a new php document.
"Significant Changes...." is still missing from the email
The fields in the "Legislative" section do not validate
Any help would be greatly appreciated.
paul_p_2_files.zip
testing your files the Significant Changes section is written to the email without an issue.
The problem with the form elements in the Legislative is that they have the same name as form elements in the Regulation section.
all form elements must have unique names.
paulp123370
geez
well hell, i clearly have not had enough coffee... i should have spotted that one..
thanks again for the ultra quick response! I'll make the changes and let you know once I have everything working.
paulp123370
email issues
I'm still having email issues. The "Significant Changes" AND the Legislative section do not show up in the emails. I made sure label names were different as well and I started fresh again by importing the form template.
Validation works perfectly.
Suggestions?
paul_p_3_files.zip
in the webassist/email/templates/block.php page, try changing:
$removeEnds = array();
$removeEnds[] = "_x";
$removeEnds[] = "_y";
to:
/*$removeEnds[] = "_x";
$removeEnds[] = "_y";*/
paulp123370
significant
Significant Changes still doesnt show up in the email but the Legislative section shows up just fine in the email.. Weird...
Thanks for the help. Not sure why that first one is acting so strange....
