Help with a delete statement
Thread begun 4/27/2011 6:46 pm by bjgarner241692 | Last modified 4/27/2011 6:52 pm by bjgarner241692 | 1202 views | 1 replies |
bjgarner241692
This is not a PHP issue, it is ASP with Access and it has nothing at all to do with WA products, but I'm hopeful that someone can help.
Why does this work?
WADAcounter_cmd.CommandText = "SELECT * FROM viewcounter WHERE extra1 Like '%+http://%'"
But not this?
WADAcounter_cmd.CommandText = "DELETE * FROM viewcounter WHERE extra1 Like '%+http://%'"
I've tried * instead of % because if you were to run it in ACCESS you would use *.
bjgarner241692
Yay - just a little more googling.
Query was fine. DB needed to be compacted and repaired as I had just removed about 20000 records prior to this.
Hope it helps someone else some day.
