Not dropping down
Thread began 7/01/2009 8:43 am by simon.j373264 | Last modified 7/06/2009 1:45 pm by Ray Borduin | 1031 views | 7 replies |
simon.j373264
Not dropping down
Hi, does anybody know why this menu doesn't drop down on this page:
index1.php
but does on it's own page here: (this is the php page being included in the above also)
navigation.php
CSS for page here: style.css
CSS for menu here: cssmw/
Thanks, Paul
xag
it's prob not the CSS..is your image in a div or your text? I had the same problem with a graph blocking the drop down so I just pushed down the graph and there it was. Check to see if its not dropping down behind your image or text.
That is correct... it is just hidden. Add z-index to make it show on top:
ul#cssmw ul.level-1 {menu.css (line 68)
left:0;
top:100%;
z-index:100;
xag
Hi Ray,
I tried to add this to the CSS page just like you said above but its still sitting behind my flash. take a look at this site (dm.asp?parm=NewPage&bk=Default2) and hover over the products tab. Attached is the CSS for the menu
css.zip
This is a problem with your flash settings... you need to set your wmode in your flash move to "transparent" see: showthread.php?t=679&highlight=menu+flash
xag
cool thanks Ray it worked. Do you think it will work the same with dynamic web charts?
xag
nope didn't work I will post something in the Dynamic web charts area
Yep it will work with dynamic web charts too... You can see an example in our powerstore demo admin which uses charts and menu writer.
