Has Anyone Else Received This Message?
Thread began 4/03/2011 8:42 pm by rachel422967 | Last modified 3/28/2012 11:56 am by Jason Byrnes | 4529 views | 13 replies |
rachel422967
For the second time now, I am receiving this message:
"While executing DXMenu_WebAssist_WAPCMS_ReUse command in menus.xml, the following JavaScript error(s) occurred:
Cannot find Server Behavior named WAPCMS_ContentNode.htm."
---> This message will not let me "add to" or "insert from" content for PowerCMS.
I have already Deleted the Dreamweaver Cache (dat) file from the users configuration folder, per Jason Byrnes' previous suggestion, but am still receiving this message upon restart.
I would appreciate a solution to this re-occurring problem. Thanks.
what version of Dreamweaver are you using?
What is your OS?
does the following file exist in the configuration folder?
ServerBehaviors/PHP_mySQL/WebAssist/CMS Builder/WAPCMS_ContentNode.htm
Did delting the cache file fix the error temporarily but now it is back, or did deleting the cache file not fix the error at all?
the DW Cache file can become corrupt for a number of different reasons and is the first thing I always try for any javascript error message in DW.
rachel422967
What is your OS?
My Dreamweaver = CS3
My OS = Mac OS X, Version 10.5.8
Yes, that file exists in the configuration folder, however, I am attaching it for your review. (It looks empty to me.)
No, deleting the DW Cache file had no effect – no difference. I still received the message.
I uninstalled the the extension and re-installed, which seemed to help for awhile, but received the message again later. (I am using the BETA version.)
Hope this information is helpful. *Also – I posted this thread in 2 forums because I wasn't sure which one to post to for this issue.
WAPCMS_ContentNode.htm.zip
amy286446
same error
Im getting the same exact error.
Mac OSX 10.6.6
Dreamweaver CS3
I have tried removing the extension, re-installing, deleting the cache file - several times.
I would appreciate your help.
twindesign.hans434519
I' ve also get the same message "While executing DWMenu_WebAssist_WAPCMS_ReUse command in menus.xml, with the following JavaScript error(s) that occurred:
Cannot find Server Behavior named "WAPCMS_ContentNode.htm"
Any solutions please? Would be very helpfull. I'm stuck on this!
Thanks in advance,
Hans
gyske292158
Same Java error on my machine
Cannot find Server Behavior.
Did dump the .dat file, reinstalled the extension, but still could not solve the problem.
System 10.5.8 on a Powerbook G4
Dreamweaver CS3
java version "1.5.0_20"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_20-b02-315)
Java HotSpot(TM) Client VM (build 1.5.0_20-141, mixed mode, sharing)
mysql5 @5.1.60_0
mysql5-server @5.1.60_0
php5 @5.3.8_1+apache2
apache2 @2.2.21_2
I would appreciate your help very much!
in the previous tickets we found the cause of the problem was caused by not defining a testing server in the Dreamweaver site definition.
see the "Defining a Dynamic Site in Dreamweaver" tutorial on the learning resources page for details on properly configuring your site in Dreamweaver:
resources.php?utm_campaign=Forum_header&utm_medium=Forums&utm_source=WebAssistForums
