Images Not Displaying
I have a new installation of PowerGallery. The images show up in the admin but not on the website page.
Here is the link: photos.php
here are updated copies of the galleries/global.php and webassist/framework/library.php files to correct the problem.
I updated the 2 files but the problem still exists.
My Power Gallery images aren't showing...nor are the gallery graphics. I noticed in the source code that there are paths being called in the source code that are not functional.
For example, my test image is trying to be called by this URL path:
However, this is the correct path:
How can I resolve this issue and remove the extraneous pathing information?
here are updated copies of the webassist/framework/library.php file and the galleries/global.php file that should correct the issue:
Jason,
I replaced the files, but the problem appears to be persisting. Do you have any recommendations?
Here is my test gallery: index.php?gallery=1&theme=dark
I am still experiencing the same problems with the gallery pages, even after replacing the 2 revised files. Should we open a support ticket?
