Dynamic Login/Logout Link
Thread begun 2/14/2011 7:19 am by ThinMan | Last modified 2/18/2011 1:31 pm by Jason Byrnes | 6342 views | 8 replies |
ThinMan
Is there way with the User Reg Pack to dynamically update a login/logout button or link if the user is logged in or not?
Yes, you can use this code to dynamically show login/ log out:
<?php if(WA_Auth_RulePasses("Logged in to users")){ // Begin Show Region ?>
<a href="users_LogOut.php">Log Out</a>
<?php // End Show Region ?>
if(!WA_Auth_RulePasses("Logged in to users")){ // Begin Show Region ?>
<a href="users_LogIn.php">Log In</a>
ThinMan
Thanks Jason!
you're welcome.
ThinMan
Jason,
For some reason, it's not posting to the page. I've got the links attached to a navigation css, so they're getting styled. That shouldn't effect the php, right?
Here's what I've got, along with your above code inserted:
<div id="navcontainer">
<ul id="navlist">
<li><a href="index.php">Home</a></li>
<li><?php if(WA_Auth_RulePasses("Logged in to users")){ // Begin Show Region ?>
<?php } // End Show Region ?>
<?php if(!WA_Auth_RulePasses("Logged in to users")){ // Begin Show Region ?>
<?php } // End Show Region ?></li>
</ul>
</div>
ThinMan
Same code as above, just in the php container.
<ul id="navlist">
<?php // End Show Region ?></li>
</ul>
</div>
do you have the include files referances on the page at line 1:
<?php require_once("WA_Globals/WA_Globals.php"); ?>
require_once('Connections/localhost.php'); ?>
require_once( "WA_SecurityAssist/Helper_PHP.php" ); ?>
ThinMan
That did it. Thanks Jason
you're welcome.
