Best WebAssist tool to use to fix IE CSS issue
Thread began 2/06/2011 7:40 am by nhtmedia421890 | Last modified 2/07/2011 10:14 am by Jason Byrnes | 1889 views | 5 replies |
nhtmedia421890
A website I'm working on for a friend is having issues with IE rendering it incorrectly vs FF and chrome.
I was wondering which tool from WebAssist will help me find the css challenge and offer a fix?
neilo
I think you are already using it, - the WebAssist support forum. If you were able to post a link to a page on your site that displays the problem in IE, it is likely that someone will be able to provide a solution.
IE has always tended to require element dimensions and positions to be fully coded, and doesn't use the same logical default fall-backs that other modern browsers have. In firefox (for example), if some elements' dimensions aren't specified, it will assume and render a value of 100% of its containing element. IE has (historically) tended to 'collapse' certain elements so they seem to be either missing or reduced to barely contain their contents, thereby messing up your design structure.
Sites built using WebAssist's CSS Sculptor or Site Sculptor correct these issues as the pages are created, - usually by including a separate stylesheet that is conditionally used if a page is viewed in IE.
If you would care to post a link to a page, someone may be able to advise.
nhtmedia421890
Posting to a forum would be great if I wanted to wait for answers. Or I could purchase a tool that could help accelerate the process.
As it turned out I found the error by using built in validation check.
I recently purchased the WebAssist Super Suite package and I was not able to find the same error with any of the tools provided. All that was wrong was a missing closing tag in the header.php file.
BTW I'm getting a few errors when launching some of the WebAssist Super Suite tools. Quite annoying really. For the price I would have expected better.
Have you ever experienced this?
Jenn
SOJO webBeta Tester
WebAssist products actually work great. The issue (which is usually Javascript errors) is caused because of Dreamweaver cache file system.
No offense, but your quick to slam WebAssist without even reading the documentation.
Check this for your startup issues: common_installation_issues.pdf
I'm pretty sure that will solve your issues. If you still have a problem, you can report and either a community member (like myself) or a WebAssist employee will make sure your stuff works correctly.
As far as your issues between IE and the other browsers, it's something all web designers deal with and there will probably never be an extension that can fully compensate for both. This is because Microsoft decided that "standards based" wasn't the route they wanted to go. In contrast, all of the other browsers decided to go standards based. The later versions of IE have been much better but still are not up to par with Safari, Firefox, and Chrome.
nhtmedia421890
Read the documentation.
Deleted the WinFileCache.dat file too. Still the Css Forms Builder is coming up with: Error Initializing Add Form UI.
This is not helping speed up my day. Instead of working on building a website right now I'm trying to fix a product I just purchased.
Slaming WebAssist Products - No. Saying I'm getting errors and that I'm annoyed by it is not slaming WebAssist. Just getting cranky. Did I mention I was cranky!
I'm actually burning up more time tracking down fixes than I would expect from a high end tool.
When I spend half a grand on something I expect it to work out of the box.
No offence to WebAssist or your loyalty to WebAssist but I have not experienced any WebAssist goodness yet.
Jenn
On the download Page for CSS form builder, there is a new build for HTML Editor 3 Compatibility, this build will also fix the error you are encountering.
you should uninstall CSS form builder from the extension manager and install the HTML Compatibility build to fix the error.
