Clear Session Values Java Error
I get 2 java script errors when I call in Clear Session Variables, both for the file WACTClearSession.htm.
The version installed is 3.1.3, I installed it this morning. Previously running 3.1.2 with the same error. I have deleted the .dat file which has not changed problem. I did have a problem with Momento after installing 3.1.3 that caused errors in a lot of places within Dreamweaver CS3; this portion of problem was corrected by removing and reinstalling CSS Form 2.0.0.
I do use this tool quite often and it always worked until 12/31/2010 when I installed new and upgraded extensions.
