$AssumedRoot Variable in live site
Thread begun 1/07/2011 11:28 am by YellowCircleWeb | Last modified 1/07/2011 4:55 pm by YellowCircleWeb | 1951 views | 2 replies |
YellowCircleWeb
I've developed a site for a client and created a CMS system. I used HTML Editor and DataAssist for this.
Recently the site has been put live but certain areas of the CMS are not working correctly because URLs are not correct. I've done a bit of research and found the $AssumedRoot variable is causing the problem, inserting an extra directory into the URL that was present on the development server I used to build the site, but is now no longer present on the live web server.
My question is: Is there a setting in HTML editor where I can change the $assumedroot variable without going into the code itself? And if there is will changing the setting in the HTML Editor UI overwrite my CSS and other code modifications?
the assumed root is taken from your site definition is derived from the HTTP Address you define on the local info tab.
anything after the domain is added to the assumed root.
if the URL is set to :
otherfolder/
then the assumed root will be set as;
/myfloder/otherfolder/
YellowCircleWeb
Thank you for the reply Jason.
I understand how this works now.
