Captcha is not working in web page
Thread began 6/22/2009 9:49 am by sornalakshmi382783 | Last modified 6/28/2009 6:17 pm by bjgarner241692 | 1272 views | 2 replies |
sornalakshmi382783
Captcha implemented in my web page , code is correct but image is not displayed in web page. I searched in error logs no errors logged related to captcha. I am not able to find the reason. Can you give your views what could be the reason.
Thanks in Advance
The GD library is not installed on your php server is one reason. Do you have a URL? That might help debug the precise issue.
bjgarner241692
Originally Said By: sornalakshmi382783
Thanks in Advance
Not sure which CAPTCHA you are using. With the one I use, in both ASP and PHP I have to remove a / from the page code in front of the directory name that holds the CAPTCHA image information.
