New Problems in 1.2.1
Thread began 1/03/2011 1:28 pm by kbettenc296716 | Last modified 1/04/2011 10:12 am by Jason Byrnes | 700 views | 1 replies |
kbettenc296716
My client changed her ID and Password. and I started getting errors trying to login to Power Gallery. I changed the ID and PW back in the mySQL table and made sure it matched powergallery.php but I am still getting these messages at the top of:
index.php
<br />
<b>Warning</b>: fopen(../admin_gallery/Connections/installed_gallery.txt) [<a href='Templates/function.fopen'>function.fopen</a>]: failed to open stream: No such file or directory in <b>\\nawinfs03\home\users\web\b1995\rh.lbehar\pg_102\admin_gallery\images\installed.png</b> on line <b>15</b><br />
<br />
<b>Warning</b>: filesize() [<a href='Templates/function.filesize'>function.filesize</a>]: stat failed for ../admin_gallery/Connections/installed_gallery.txt in <b>\\nawinfs03\home\users\web\b1995\rh.lbehar\pg_102\admin_gallery\images\installed.png</b> on line <b>16</b><br />
<br />
<b>Warning</b>: fread(): supplied argument is not a valid stream resource in
<br />
<b>Warning</b>: fwrite(): supplied argument is not a valid stream resource in <b>\\nawinfs03\home\users\web\b1995\rh.lbehar\pg_102\admin_gallery\images\installed.png</b> on line <b>18</b><br />
<br />
<b>Warning</b>: fclose(): supplied argument is not a valid stream resource in <b>\\nawinfs03\home\users\web\b1995\rh.lbehar\pg_102\admin_gallery\images\installed.png</b> on line <b>19</b><br />
<br />
<b>Warning</b>: mysql_free_result(): supplied argument is not a valid MySQL result resource in <b>\\nawinfs03\home\users\web\b1995\rh.lbehar\pg_102\admin_gallery\global.php</b> on line <b>37</b><br />
You have another ticket open with our engineers, i have added this issue to that ticket, we will look into this when we look into the other problems you are reporting.
