Include user ID in email log
Thread began 12/21/2010 10:14 pm by webmaster118088 | Last modified 9/04/2012 12:13 pm by Jason Byrnes | 4903 views | 26 replies |
webmaster118088
Good evening, I would like included in the email log the id of the user who sent you the e-mail, I tried the recordset from which collects multiple addresses to send them but just insert the id of the first record in all log records.
I would also like to know how to implement the user name in the message body as in previous versions was as simple as placing the body in the recordset user name field.
The data for sending the collected from a mysql user table for mailing.
Add this to the top of the email body template page:
global $RecipArray;
global $RecipIndex;
and in the body and for the email log settings use:
<?php echo($RecipArray[$RecipIndex][0]["[yourColumnName]"]); ?>
and you can add any references to the recordset columns used as the To loop.
webmaster118088
Solucionado
Solucionado,
En el archivo de la recogida de datos he añadido esto:
$CurIndex = sizeof($RecipArray);
$RecipArray[$CurIndex] = array();
$RecipArray[$CurIndex][] = $row_rsusersmail;
$RecipArray[$CurIndex][] = $rsusersmail;
$RecipArray[$CurIndex][] = "UserEmail";
$TotalEmails += mysql_num_rows($rsusersmail);
$RecipArray[$CurIndex][] = "UserID";
Y en el de envío esto:
//Success Or Failure
$MailLogBindings->SuccessOrFailure->ToDo = "insert";
$MailLogBindings->SuccessOrFailure->Connection = "conexionmysql";
$MailLogBindings->SuccessOrFailure->TableName = "email_log";
$MailLogBindings->SuccessOrFailure->EmailColumn = "EmailTo";
$MailLogBindings->SuccessOrFailure->ColumnList = array("NumeroDeMailing", "EmailLogUserId", "EmailTo", "EmailFrom", "EmailSubject", "EmailBody", "EmailHeader", "EmailError", "EmailStatus");
$MailLogBindings->SuccessOrFailure->TypeList = array("',none,''", "',none,''", "',none,''", "',none,''", "',none,''", "',none,''", "',none,''", "',none,''", "',none,''");
$MailLogBindings->SuccessOrFailure->ValueList = array("".$row_rsmailuser['id_mailing'] ."", "".$RecipArray[$RecipIndex][0]['UserID']."", "".$_SESSION["waue_mailing_presentacion_miscasas_1_To"] ."", "".$_SESSION["waue_mailing_presentacion_miscasas_1_From"] ."", "".$_SESSION["waue_mailing_presentacion_miscasas_1_Subject"] ."", "".$_SESSION["waue_mailing_presentacion_miscasas_1_Body"] ."", "".$_SESSION["waue_mailing_presentacion_miscasas_1_Header"] ."", "".$_SESSION["waue_mailing_presentacion_miscasas_1_Log"] ."", "".$_SESSION["waue_mailing_presentacion_miscasas_1_Status"] ."");
toms016390756
global $RecipArray;
global $RecipIndex;
Thanks I needed that.
cjohnson335078
This works, thanks - will this be part of a future update? Wondering if there a use-case where this wouldn't make sense?
We could automatically add:
global $RecipArray;
global $RecipIndex;
to the templates, but you'll still have to use the correct syntax when referencing the content on the page... we can try to figure out a better way to address that in the next update.
cjohnson335078
Also, to get a EmailTo_UserID field into the email_log table - using the above syntax/approach - ie: ($RecipArray[$RecipIndex][0]["UserID"]) as the "value" for my custom added EmailTo_UserID column in the mail log settings file - the UE window reports a non-terminal error and will remove the code below on update of the UE editor behavior.
The thing is - this code/approach works (tested). Is there any way to make it stick and not crash/disrupt the editor?
I'll have to look into it further. What is the exact error you get and when exactly do you see it? I'll send this thread to someone in our QA department to try to reproduce it and log a bug.
ryanteets270615
this doesn't work for me.
I have this code in my page and still the values are not being received by the email body.
Can you open a ticket for me so I can send you my files?
I have opened a support ticket that we can use to further debug this issue.
