Webassist CSS Form 2, can't Edit Form
Thread began 12/01/2010 7:27 am by tops367539 | Last modified 12/07/2010 9:18 am by tops367539 | 3802 views | 12 replies |
tops367539
I create a Webassist CSS form in CS5, all goes well, but when I try to Edit Form I get Dreamweaver Error "Error Initializing Add Form UI: ReferenceError: theServerLanguage is not defined"
I have no trouble with Edit Design and Edit Contents.
I have followed similar type errors with deleting cashes, to no avail.
In the Site definition go to the servers tab.
Make sure that a testing server is set, if you only use a remote server, you can check both Remote and Testing for the one server. Then go to the advanced tab and set the server modal to PHP MySQL.
tops367539
No Joy yet
I had two servers, one to do the FTP to the Remove Server and a localhost one to do the Testing Server. I have deleted the Testing Server and then ticked the Testing box on the Remote Server and set the PHP MySQL in the advanced tab. Now the Live View does not work anymore and neither does the Edit Form.
Dont delete the testing server.
If you already had a testing server, then you only needed to change the server modal.
put back the local testing server, and just make sure the server modal is set to PHP MySQL.
My meaning in the previous reply was to say that IF you only use a remote server, then you should set it to be your testing server as well, but only IF.
tops367539
Still no joy
That's the way I started out with the PHP MySQL set in the testing server, advanced tab. I could see everything in the live view. Everything works as it should, except the Edit Form. My work around is to delete the form and start again from start, most anoying.
can you send a copy of your page please.
tops367539
I attach the file
I attach the php file
volunteer.zip
in the source code pf the page, I see 2 instances of the server validation server behavior and 2 instances of the universal email server behavior.
try deleting the duplicate server validation behavior and the duplicate universal email behavior.
tops367539
Confused
How do I do this? must I go in and ammend the code? or do I delete the form and set it up again with different options? Because if you are asking me to go in and ammend code, it defeats the purpose of me buying Webassist as my php experience is in its infancy.
go to the server behaviors panel (Window -> Server Behaviors) select the duplicate Server Validations server behavior and click the minus button. Then select the duplicate Universal Email server behavior and click the minus button again.
