Javascript Error findDynamicSources
Thread begun 11/27/2010 3:10 pm by Daryl | Last modified 7/11/2011 9:20 am by Jason Byrnes | 6268 views | 12 replies |
DarylBeta Tester
I keep getting the following error;
  While executing findDynamicSources in WA_NotifyCO_0_Gen.htm, a JavaScript error occurred.
This error is seen whenever a page is loaded that contains items created by a WA extension.
I have tried deleting the Win Cache Folder with no luck
I have renamed the configuration folder which did work!
I then re-enabled the WA extensions and the error came back
I removed all extensions and the error message was resolved
I re-installed all my extensions and the error has come back
I am using the latest version of Dreamweaver CS5 on a fully updated Windows 7 system and am using the latest versions of WA extensions.
Any ideas?
anonymous
Daryl,
One thing to check is other extensions in use. Are any other extensions installed and if so, which ones?
Best regards,
Brian
Please send a screen shot of the extension manager showing the installed extensions and versions.
DarylBeta Tester
Here ya go
DarylBeta Tester
Any ideas what causing my problems?
anonymous
Daryl,
I had the same problem when I installed that 960 Grid System extension from DMX Zone. They clearly didn't do much research on it and kind of released way to early without testing. Since I had been a fan of the 960 Grid previously, when I saw the free extension, I figured I would give it a go. Then I quickly found out that it kept causing similar problem. I think they have released a few updates since, but I just completely deleted the extension off and that solved my problem.
Best regards,
Brian
Dave BuchholzBeta Tester
Daryl,
I'm with Brian on this the 960 extension caused me issues as well
DarylBeta Tester
I have removed all non WA extensions and have deleted my wincache file but still get this error message....
Any other ideas?
CraigRBeta Tester
interested in result of this, i had the problem this week.
reverted to earlier version of my site, and problem hasn't returned.
only WA extensions installed, DWCS5, Windows 7
