client validation producing bad code
Thread begun 11/01/2010 2:24 am by Hervé | Last modified 11/02/2010 10:48 am by Hervé | 2492 views | 4 replies |
Hervé
i have a data assist insert form and i try to validate serie input field (must be integer) but generated code is wrong, seems to be default values.
see attachements : client validation entries and code - extension versions i use
thanks
I am not able to reproduce the problem using CSS FORm Builder 1.0.2 in Dreamweaver CS4 on Mac OS 10.6. 4
What version of Dreamweaver are you using?
What is your OS?
can you send copy of your page so I can try to reproduce the issue.
Hervé
client validation issue
i send you my page and mysql table.
i'm using dreamweaver cs4 on xp sp3, php 4.3 and mysql 5.0.51. firefox 3.6.12
i have same problem with my upgrade page.
if i handcode my values min -100000 max 100000 #decimals 0 insert/update page works right but if i enter client validation wizard again it show min 100000 max 0 #decimals ''.
this happens if i select european or internationnal number format. i have given some tries using english format and it seems to work right way.
i'll test further tomorrow and let you know.
Did you have a previous version of validation toolkit installed before installing form builder?
Try deleting the Dreamweaver cache file from the users configuration folder:
Hervé
yes, previous VT extension was uninstalled BEFORE installing form builder
i already delete dreamweaver cache file without changes
