Installation stalls after Step #2
Thread begun 10/18/2010 12:24 pm by info72555 | Last modified 10/20/2010 9:31 am by Jason Byrnes | 2790 views | 5 replies |
info72555
I am trying to install 1.11 but after I enter the database and connection information and click Next, I am getting a blank page. When I view the page source, there is no code.
I have removed the entire Power Gallery directory, deleted the database and started from scratch - same results.
Any ideas?? Thanks
is it install/2.php that displays blank, or install/3.php?
add the following code to the page that displays blank at line 1:
error_reporting
(E_ALL);
this will turn error reporting on to help us figure out what is going wrong.
info72555
Error message: completed step #2 but stalls on 3
Fatal error: Call to undefined function mysql_set_charset() in /home/dreams/public_www/CMS/Photos/Connections/powergallery.php on line 10
what version of MySQL are you trying to install on?
info72555
MySQL version
It's version 5. What I don't understand is that the Power CMS is also installed and working on this account so why would the Gallery not work?
what version of php?
the mysql_set_charset command wasn't introduced until version 5.2.3.
We updated power gallery to force the db to use the UTF8 character set to address a problem people where having when trying to store special characters in the image description.
you can get around the error by going to Connections/powergallery.php and Install/scripts/connection.php and changing line 10:
mysql_set_charset('utf8',$powergallery);
to:
//mysql_set_charset('utf8',$powergallery);
but if you try to use special characters in the image description, you will run into issues.
