Center menu
Thread began 6/11/2009 11:47 am by meister281653 | Last modified 6/11/2009 4:55 pm by meister281653 | 1336 views | 7 replies |
meister281653
Center menu
how can I center my created menu with CSSMenuWriter? its only left or right possible.
Denis
Do you have a sample page? Usually you can place the menu inside a div that is centered and that would center the menu.
Neil Beadle
How to center your Menu Writer menu on your page
We have a How To on how to center your Menu Writer menu on your page.
Go to the CSS Menu Writer Support page, and look under How To's.
css-menu-writer/
meister281653
haha looks good, when i delete all the widht, padding, margin from the menu.
index10.php
my menu should be 900px width.
or 100% in the DIV i put it into.
all is done with your products. why is there a function to CENTER the MENU.
Neil Beadle
Denis,
The instructions say to measure the full width of your menu, not the width of the div your menu is in. Your actual menu is only 530px wide.
You should be specifying the following for your TopNavigation div:
margin-left: auto;
margin-right: auto;
width: 530px;
meister281653
its not only the menu...
look at this. i just created it with sculptor and menuwriter. no errors shows up.
index12.php
and? check. great huh?
this extensions dont make it easier
what am i doing wrong?
It looks like you could have done lots of things. What exactly were you doing when the problem started?
You need to take it one step at a time and back up good copies. Maybe start over with the file you had this morning that seemed very close but had a gap below.
That way when you make a change you can see the effect. You will know what you did to cause a problem, and you don't have to ask what change you made. It might sound like a slight difference, but the difference may be between being able to help or not. If you do a bunch of things and say "what did I do wrong" without even being specific about what exactly you did and why you were doing it, it is nearly impossible to tell you what you did wrong.
meister281653
thanks
I centered it with my placeholder.
maybe that would be NICE for an UPDATE :-)
_index.php
Cheers and thanks
Denis
