JavaScript Error in Dreamweaver CS5 Startup
Thread begun 9/01/2010 12:32 pm by alfloyd11399466 | Last modified 5/20/2014 8:45 am by Jason Byrnes | 3274 views | 3 replies |
alfloyd11399466
I have read the posts concerning the following error:
At line 157 of file C:\Users\****\AppData\Roaming\Adobe\Dreamweaver CS5\en_US\Configuration\Shared\WebAssist\Library\WA_XML.js: XMLString has no properties.
I am running with Windows7 (64 bit). Is there a way I can get rid of this error. after hitting ok, Dreamweaver works fine with all of the extensions.
What extensions do you have installed? and what versions?
It sounds like you may have an extension that is not compatible with DWCS5 installed.
michaelf0199272
I have similar issues ---
What is your OS?
What extensions are installed, including the version numbers?
What version of Dreamweaver are you using?
Have you tried reseting the workspace layout:
go to Window -> Work Space layout -> Reset '<your layout name>'
and Delete the Dreamweaver Cache file from the users configuration folder:
http://www.webassist.com/tutorials/Common-installation-issues
