Comparative chart
Thread begun 8/22/2010 11:57 am by mdsayeed_u394092 | Last modified 8/23/2010 11:07 am by Jason Byrnes | 2648 views | 5 replies |
mdsayeed_u394092
Comparative chart
Hi
I have one requirement from client, he wants comparative chart (i.e., comparison between two column from different table like how many proposal from a month from proposal table then how many agreement a month from agreement table
Please I guide me
thanks
You will need to create a combined chart for this.
See the "Creating combined charts with the XML Editor" tutorial in the Solution recipe section of the Dynamic Web Charts support page:
dynamic-web-charts/
mdsayeed_u394092
Hi chart dialog box hang during creating chart
Hi
I have been facing this issue/bug in webchart, whenever I want to create chart from recordset, chart dialogbox getting not responded
I tried on different machine with different DW version
Is this bug
is your mysql server a local testing server or is it remote?
If it is a remote server, you should consider using a local testing server.
See the tutorials for installing a local testing server on the Learning resources page:
resources.php
mdsayeed_u394092
it is remote
It is remote server,and why should i go with local any reason?
in some cases the MySQL server will not allow outside connections.
Even if the server does allow for outside connections, Dreamweaver will need to access the server quite a bit wile generating the code and will sometimes hang up on establishing the connection.
When you use a local testing server, the connection to the database is much faster and will not hamper the development process.
