Dreamweaver CS5 crashes when dataAssist final step
Thread began 8/20/2010 3:45 pm by jerry.mccreary413430 | Last modified 8/20/2010 3:52 pm by Jason Byrnes | 1332 views | 1 replies |
Dreamweaver keeps crashing after clicking the "Finish" button in DataAssist. I've tried numerous times, using different db tables, deleting the .dat file, re-installing DataAssist, etc.
The "Results" page will save and function correctly. I can see the other pages (Search, Detail, Insert, etc) being built, but they are not saved, as Dreamweaver crashes during the final step.
Need help. Thanks.
Do you have a local testing server setup?
I have seen this issue occur when the pages are being built using a remote database.
If this is the case, you should setup a local testing server for development. see the tutorial on the learning resources section:
resources.php
If you are already using a local testing server, try closing the file and server behaviors panels before starting the DataAssist wizard.
