Editing (renaming) simple option name fails
Thread begun 8/20/2010 12:27 pm by johnb | Last modified 8/25/2010 10:19 am by Jason Byrnes | 2119 views | 4 replies |
johnb
Once a simple option is set up in PS3 it has links to edit and delete. Delete is working but the edit name is not. It allows you to enter in a new name in the modal window but when you apply it nothing happens.
Any Ideas?
johnb
Should I ask this question somewhere else?
I have seen this issue occur if the option names contain an apostrophe ('). If you have apostrophes in the option names, you will need to remove them in the ps3_options table of the power store database.
johnb
Do you mean any name in the entire options table or just the option you are trying to change the name of?
it mostly only effects the option you are trying to change, but any option in the database may also cause a problem.
