Redeclare of rel2abs()
Thread begun 8/14/2010 6:42 am by cboyd269911 | Last modified 8/29/2010 6:23 pm by danielsebas | 6987 views | 17 replies |
cboyd269911
I built a website using Site Sculptor and then attempted to add a framework plugin. This resulted in the following error:
Fatal error: Cannot redeclare rel2abs() (previously declared in /home/admin/public_html/webassist/framework/library.php:15) in /home/admin/public_html/WA_CMS/library.php on line 21
I attempted to rectify the problem by changing the following line in WA_CMS from
require_once("library.php");
to:
if (!function_exists('rel2abs') && !function_exists('abs2rel')) {
That appears to get rid of the redeclare error, but now my plugin appears twice. Once in its proper location and again in the upper left hand corner of the page.
How can I correct this?
Many thanks!
I've opened a support ticket so that I can look into this problem with you directly. Please update your incident ticket with a good time and phone number where we can reach you.
superpac250441
Hi there,
I am getting the same error message:
Fatal error: Cannot redeclare rel2abs() (previously declared in C:\xampp\htdocs\CMStest\webassist\framework\library.php:15) in C:\xampp\htdocs\CMStest\WA_CMS\library.php on line 21
The template used was from site sculptor using CMS. I note 2 library.php files, one in framework folder and the other in WA_CMS Folder so presume that is the cause of the redeclare rel2abs() although I am guessing
Please would the solution to earlier inquiry be posted here
the solution is to wrap the function declarations in each of the library.php files with:
if (!function_exists('{functionname}')) {
//function goes here
where {functionname} is replaced by each function in that file, and each function is wrapped in this way.
We'll have to update powerCMS to account for this in the next update.
superpac250441
Error on Library files
Hi Ray, I have tried to use your code on the functions but I cannot get it to work. Would you be kind enough to take a look at the attched 2 library files and place the code in ot for me to look at so I can learn?
Many thanks
Open up the file and find the functions listed inside.
The will look like:
function functionname(arg1,arg2,etc) {
add code around them so that they look like:
if (!function_exists('functionname')) {
do this to the abs2rel and rel2abs functions in those two files. We'll be releasing an update to framework builder to address this issue as well as a handful of others reported since the release. That update should be available in the next week or two.
superpac250441
Many thanks Ray
saf01
Hi after coverting site sculptor site to framework themem i get the rel2abs error and followed the instruction to fix the problem.
Now I get
Warning: strpos() [function.strpos]: Empty delimiter in C:\wamp\www\sitesculptor\webassist\framework\library.php on line 20
what am i doing wrong?
I have opened a support ticket so that we can investigate this issue further. I'll try giving you a call today in order to look into it with you directly.
saf01
Thanks Ray. Ive updated the ticket. Look forward to hearing from you.
