Unidentified Error Has Occurred!
Thread begun 8/07/2010 2:05 am by willo009412397 | Last modified 8/09/2010 11:04 am by Eric Mittman | 1327 views | 1 replies |
willo009412397
Hi guys
Im using cs5 and dataassist2 on step1 of the dataassist wizard im getting this error
"Unidentified error has occurred!" any help will be very welcome.Thanks
regards karl
Is this a js type of error or is that the entire error message you are getting? If that is the entire error message I have seen this happen before where DW had a problem with the connection and could not work it out. If this is the case there are a couple of things that you can try to help with this:
Recreating the site cache
Go to Site > Advanced > Recreate Site Cache
Resetting the workspace layout
Window > Workspace Layout > Reset
If these do not resolve the problem you can try deleting the cache file with the instructions here:
If the problem persists after this there might be a problem with the connection and you may need to remove it from the site and add it again as a new connection. Please post back and let us know how it works for you.
