javascript error
Thread begun 6/05/2009 3:47 pm by edrosenthal350859 | Last modified 3/24/2010 7:01 pm by arodriguez394222 | 5209 views | 3 replies |
edrosenthal350859
javascript error
Is somebody working on fixing the onMouseUP javascript error in wajz_validator.htm?
Indicated in the FAQ for this error is a very inconvenient fix, to remove the setup and redo the setup with the SAME entries? How soon before this is fixed? I just purchased and downloaded and want to use it, but.
Thanks in advance
-eddie
I am not familiar with this error. What is the url for the FAQ you are talking about?
biesheuvel378713
Well better late then never, maybe you've got the problem allready fixed...
Sometimes the webassist extensions give these sorts of errors, it's probably solved when you delete this file:
C:\users\~username\appdata\roaming\adobe\dreamweaver cs4\~contrycode\configuration\winfile*****cache.dat
Greetings...
arodriguez394222
this just solve my ecart problem
thanks a solve a similar problem with ecart 4.5.2
