Any way to remove the location info "bubble"?
Thread begun 6/05/2009 6:03 am by Nathon Jones Web Design | Last modified 8/06/2009 1:20 pm by Ray Borduin | 7888 views | 15 replies |
Is there any way to remove the location info bubble from the map?
I just want to have a flagged point on the map as I have the location info alongside the map plus I don't really like the way the bubble covers the map.
I've had a look at this line in the wagmp_map_1.asp file:
var address_0 = {
street: '',
city: '',
state: '',
zip: '',
country: '',
infowindow: 'custom',
infowindowtext: '<span style="font: 12px Verdana, Arial, Helvetica, sans-serif; color: black;">Bubble Text Here</span>',
full: '<%=Replace(Cstr("" & cStr((rsEVENT.Fields.Item("googlelatitude").Value)) & ""), "'", "\'")%>,<%=Replace(Cstr("" & cStr((rsEVENT.Fields.Item("googlelongitude").Value)) & ""), "'", "\'")%>'
Can I edit a setting here that would prevent the bubble from displaying? Thanks.
Nathon.
Might have got it.
I've removed the following line from the wagmp_map_1.asp file:
icon_0.infoWindowAnchor = new GPoint(8,3);
...and that seems to have done the trick. Removing that line won't cause any problems, will it?
Nathon
I would just comment the lines that have .openInfoWindow instead of that line.
How do I comment out a line? Sorry, I know I should know that but it's not something I ever really do. Thanks Ray.
add two slashes in front of it: //
Even if it's an ASP page?
Any occurences I have in wagmp_map_1.asp, of .openInfoWindow are prefixed with "marker_0". Does that matter?
I am talking about the client side javascript code. The server language doesn't matter.
Every occurence?
.openInfoWindow appears six times in my wagmp file. I've commented them all out, by adding the two forward slashes at the start of that line, but I'm now getting "error on page"?
I'm not sure if it's important but they're .openInfoWindowHtml not .openInfoWindow. Does that matter?
Here are the six lines that have that code (now commented out):
Line 184:
// marker_0_<%=CStr(rsEVENT_2_0_repeat_index)%>.openInfoWindowHtml(address_0_<%=CStr(rsEVENT_2_0_repeat_index)%>.infowindowtext);
Line 191:
Line 212:
Line 219:
Line 235:
Line 242:
Any idea's why this is now producing the error?
Regards
Nathon
that looks right.
Do you have a url where I can view it?
If you remove the comments you don't get an error any more?
Link
Here's a page with that on, without the comments:
scottish-music-event.asp?e=935&b=1
...and yes, you're right, I no longer get the error.
Did you want me to re-write IN those errors so you can take a look?
