Site is indexed by Yahoo, but no results returned...
Thread begun 7/23/2010 11:34 am by dev396590 | Last modified 7/30/2010 6:53 am by Jason Byrnes | 6590 views | 12 replies |
dev396590
Would it possible to take a look at this site and determine if there is something awry with the search box coding. I'm guessing this could be the culprit, as all else seems OK:
2aqewjb
Just found the following on the forum and updated the code, and now the 'No results found...' message is gone, but still nothing appears in the results region:
<?php if($_SERVER["REQUEST_METHOD"] == "POST") { ?>
if ("".($Search1_BOSS_all) ."" == "0") { // WebAssist Show If
<div>No results found matching your search.</div>
} // ("".($Search1_BOSS_all) ."" == "0")
<?php } ?>
Thanks in advance for any help!
can you send a copy of the results page please.
dev396590
Thanks, Jason!
Please let me know if you can work with the attached...
Thanks again!
dev396590
Anybody home?
Client getting restless. Would appreciate a little help...
The search for boss behavior is set to trigger on a form element named "Search", your search box is named "s":
change:
<input type="text" value="" name="s" class="searchbox">
to:
<input type="text" value="" name="Search" class="searchbox">
dev396590
Thanks!
Thank you, Jason. I'll give that a shot in the morning. Much appreciated...
you're welcome.
dev396590
No luck!
As a test, I've replaced the code as indicated about on one page prior to going site-wide, and getting same outcome — nothing appears in the 'results region'. Here's the page that was updated: 262d77d
Thanks again for your time on this one, Jason. Hopefully it's an obvious error that I've overlooked. Let me know if there is anything else you'll need. Thanks!
I get a result on that page if i use the search term "services"
dev396590
Wow!
That is odd. I tried obvious terms (like 'spices') and nothing. But sure enough, 'services' renders a result. Maybe not all pages have been indexed by Yahoo! yet? Would love to know the reason, but happy all is well otherwise ;-p
One more quick question if you don't mind: How would I apply CSS to style the actual results?
Thanks again for time and guidance on this, Jason. Very much appreciated!
